Switch asks to detach when playing games
When playing games Switch requests joy controllers to be detached to carry on playing
Update (02/24/25)
Esta é uma boa pergunta?
Hi!
Thanks for the video!! It looks like either the Switch it’s rail failed, or the joycon it’s rail.
Did you tested the Joycons on another Switch? This would be the ultimate test. If they work on another one, it’s your Switch it’s rails. If not, it’s the joycon..
You can also test other joycons on your Switch and see how that goes!
Esta resposta foi útil?
Thanks I don’t have access to another Switch unfortunately. Are these issues repairable?
Yes! Both of them can be repaired :)! Usually it's the Switch it's rail that failed. But we can't be sure. Is there a way to test another Joycon on your Switch? Anyway, if you need to replace the rail on the Switch. You can find the part and guide here: Nintendo Switch Right Joy Con Sensor Rail Replacement
Do you repair them as well or are these relatively easy to repair?
Yes, I repair many of them! It’s an easy repair! You do not need to remove many components to get there, so that is always a plus :)!
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 41
Duração total: 41
5 comentários
Hi!
Can you share some pictures with us or a video? Thanks!
por koppie007
Please see attached video
por JimH830572
Please see attached video[video|6626]
por JimH830572
Hi! Still can’t see it :(. Can you upload it somewhere? Sorry!!
por koppie007
[video|6626]
por JimH830572
