Ir para o conteúdo principal
Apple's top-of-the-line flagship for 2022. Released September 16th, the iPhone 14 Pro Max sports a 6.7" ProMotion OLED, the new Bionic A16 chip, a triple rear camera system, and 5G connectivity. Successor to the iPhone 13 Pro Max.
20 Perguntas Visualizar todos
Static noise on video recording from back camera.
Hello.
My iPhone 14 pro max has a really bad video sound recording from back camera.
When I record a video with any of the back cameras the sound quality is really poor. It’s recording a real bad static noise.
Changing the settings for the video recording its not helping.
Is there a solution for this problem?
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
Did you get the phone excessively wet? Is the display slightly pulled from the case creating a gap for water to enter?
por
No my phone is in perfect condition.
The phone is dry ,never was in contact with water.
por
Adicionar um comentário
1 resposta
Well, that only leaves the front facing microphone is part of the earpiece iPhone 14 Pro Max Earpiece Speaker if you look at the image of the part you’ll see two gasketed openings one is the earpiece speaker the other is the microphone.
It’s likely the microphone is bad. Do you still have AppleCare? If you do this would be covered under it.
Imagem de Replace an earpiece speaker compatible with the iPhone 14 Pro Max model A2651, A2893, A2894, A2896, or A2895. Fix problems with phone call audio.
Produto
$29.99
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Dimitar Timev será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 18
Duração total: 18
