Ir para o conteúdo principal
The March 2015 update of Apple's 13" MacBook Air features fifth generation Intel Core i5 and i7 processors, resulting in slightly increased performance and battery life.
GPU Failiure only on the built in display?
I have a Macbook Air 2015 A1466 which has been here a while hiding in the corner which we have checked before for a display issue. Tech guy said the GPU had failed but there was a picture using an external display if I remember rightly, problem is that it don't power up anymore, so before I look into fixing the power up issue is it possible the GPU could only display externally and never again on it's built in display if it had failed?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
There is only one GPU unit, it’s not possible for the GPU to fail applying an image on one display and not another if it were to fail.
While it can be confusing as the data path from the GPU does go through a bunch of switch logic before it gets to the target display which could be the failure as well as the LCD display and its support logic (T-CON). The GPU in its self won’t be where I would look if one display worked and another failed.
Esta resposta foi útil?
Pontuação 1
1 comentário:
Yes, this is my thoughts also and is what triggered me to post this question. I shall try to resurrect the power supply and get this ones fan spinning again.
por
Adicionar a sua resposta
livfe será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 6
Últimos 30 dias: 17
Ao todo: 173
