Ir para o conteúdo principal
Repair guides and information for the Nintendo Switch Joy-Con controllers.
20 Perguntas Visualizar todos
Replacement analog for right side
After replacing the right joycon the controller wonders and acts like the A button. When I then move the joycon analog stick it stops but doesn’t register the input. Is this a bad part or did I do something wrong the other one worked fine.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi!
Well, first things first! Is the Switch and the joy-con controller up to date??
Did you also calibrated the analog stick??
If both are yes, then return the part and get yourself a new one. It’s possible that the one you have is faulty!
If you can share pictures with us or a video, that would be great! Thanks!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Geo Stelar será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 0
Duração total: 8
