Ir para o conteúdo principal
Repair guides and information for rice cookers.
Zojirushi Induction Rice Cooker loud buzzing sound when plugging in
What does a loud electrical buzzing sound indicate? The sound is similar to an AC when it’s cycling on. It may be overloading the circuit. Loose wire? Major part failure?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Induction cooking uses magnetic fields to heat directly, rather than using thermal conduction. The magnetic field is created by the 60Hz (or 50Hz) AC power. If something is loose, the magnetic field will vibrate it. It likely will need disassembly to find what is loose and fix it.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Myki Mike será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 23
Ao todo: 239
