Ir para o conteúdo principal
Known as the ''PS2'', it is a sixth-generation video game console first released by Sony in Japan in March 2000. The United States saw it later in 2000 with the SCPH-30000. Repair of this device requires only common tools, but can get tricky.
PS2 FAT Mod. SCPH-50004
Hello everyone.
I have a doubt. Perhaps someone can help me because I'm a bit of a novice in this.
I'm trying to fix a PS2 FAT Mod. SCPH 50004 that does not turn on. The problem is likely the power supply. I'm looking for one in Internet and I've seen that they have in Aliexpress, but most of them are for PS2 Fat 35008/50000 50001 50006. Do you know if they are compatible? I don't see any exclusively for model 50004.
Thank you very much in advance.
Greetings.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Don’t quote me on this… but I might have found what you need:
https://www.aliexpress.us/item/325680395...
It says that it’s for models 5000X, which should include 50004 (I think). Someone in the comments said it worked perfectly for their 50004. It’s less than $5.
Hope this helps! Have a great day and God bless!
Esta resposta foi útil?
Pontuação 2
2 comentários:
Thank You for Your help!
Unfortunately it's not available in my region but I've found one in Wallapop.
Thanks!
por
@jclvro Glad you found one! Hope it works!
por
Adicionar a sua resposta
jclvro será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 16
Últimos 30 dias: 35
Ao todo: 395
