Ir para o conteúdo principal
The 3rd generation iPhone SE was announced on March 8th during the Peek Performance Apple event. It features an A15 chip and a 4.7-inch LCD display, similar to its predecessor, the iPhone SE 2020.
Changing Battery Tool compatibility
Can I use the same tools that came with the MacBook battery change kit to replace the iPhone SE battery?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
There is little information in your post about what kind of tools you received. But knowing the iPhone SE 2022, a battery replacement will require heat, time, specialized screwdrivers, a suction cup to pull the display off.
Check out the following guide for more info:
iPhone SE 2022 Battery Replacement
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Lito Fernandez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 4
Últimos 30 dias: 21
Ao todo: 144
