Why my phone is not connect with PC using wire?
I want connect it with PC using cable or wire
Esta é uma boa pergunta?
Is the phone receiving power but not data, or is it not receiving power at all? I would try verifying that the cable works by checking to see if the cable works with other devices, or if trying to use another cable resolves the issue. If the cable transmits power but not data, it may be a power-only cable, which means the issue can be solved by using a cable that supports data transfer.
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 1
Ao todo: 50
