Ir para o conteúdo principal
Repair and disassembly information for the HP EliteBook 840 G4.
20 Perguntas Visualizar todos
I didn't turn it on
When I put the charger in it gives a signal but when I try to turn it on it doesn't turn on help me please
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
@upthiladiifyare you are not giving us much to work with here. Letting us know if anything happened that may have caused this (i.e. software update, mechanical fall, power outage) would be nice. The more detail that you can provide, the better your chance of getting a workable answer.
Start off with the easy things. Disconnect the power from the computer by unplugging the power cord from your computer. Disconnect all external devices from the computer. Remove the battery Now hold the power button depressed for about 30sec-1min. Reapply the AC power adapter and see if your computer does show any sign of life.
Next you want to check your power supply. Make sure it has the proper voltage. Check to make sure that the connectors are not bend etc. Check the DC-in jack of your laptop. Make sure there is no corrosion, debris etc. that prevents it from working. Clean it of any debris etc, use a few puffs of air to clean it out. If none of this works, get an ammeter and see if your laptop draws any amperage from the charger. After that, you need to check and see if your motherboard even gets power. For that of course, you need to open it up. Post Some good pictures of what you see. That way we can see what you see.
It is also possible that this is a bad RAM module or a bad LCD. So remove the RAM, clean the contacts with a pencil eraser. Do it gentle so as to not destroy the module. Replace it and restart. If you have more than one module, remove it and just leave one connected.
Connect and external monitor and see if that shows anything different when your laptop starts up. Use the HP EliteBook 840 G4 Service Guide to work on your computer.
Let us know how things are working out with each check/test.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
UPTHILADIIF YARE será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 12
Ao todo: 32
