Ir para o conteúdo principal
Informações sobre reparo, desmontagem e solução de problemas para o smartphone carro-chefe "menor" de 2023 da Apple, lançado em 22 de setembro. Ele apresenta uma tela OLED ProMotion de 6,1", um sistema de câmera traseira de lente tripla e 5G. Sucessor do iPhone 14 Pro.
16 Perguntas Visualizar todos
Camera won’t calibrate
Camera won’t calibrate. Keeps saying no objects found, restarts camera & goes back to finish repair.
Esta é uma boa pergunta?
Pontuação 0
2 comentários:
You probably have a ripped camera flex or some dirt between the connectors. You could try to disconnect the cameras again, clean the connectors with some IPA and reconnect. Be sure to check the flex cables for rips or hard fold lines.
por
Camera was cleaned & checked, not sure I want to go to the trouble of opening it again. Camera works fine just won’t calibrate
por
Adicionar um comentário
1 resposta
Did you use an original part from Apple? As long as you see an preview, when you do the calibration, make sure there are objects within your surrounding. This can be items on your desk or furniture in the room. This proces can be a bit long but just keep turning the phone until is says finished. Hope this helps.
Esta resposta foi útil?
Pontuação 0
1 comentário:
The camera was purchased on ifixit, when I do the calibration it says Apple part . I’ve made sure there’s objects in view, it doesn’t recognize them & they are large objects. I get the same message over & over. Then it restarts & the same message appears that I need to restart & finish repair . I’ve tried this many times & it just won’t calibrate.
por
Adicionar a sua resposta
Hairstylistroxx será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 5
Últimos 30 dias: 13
Duração total: 32
