Ir para o conteúdo principal
A2115 / 2019 / Processors from 3.0 GHz 6-core i5, up to 3.6 GHz 8-core i9. Released March 19, 2019.
Ants inside the screen
Hi everybody. I Have 2 dead ants inside the screen of my iMac 27 2015. Do you think it's possible to open the screen and remove then ? Tks.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
While I’m surprised they found their way in, LG did encounter an infected foam sealer with small flys about 2014 Apple did have a repair program to deal with the issue. Sadly that’s long since passed as an option here.
There really is no means to open the display panel without making more of a mess. The front glass is sealed to the LCD panel and just the process of cleaning the sticky glue will just smear and any dust in the air will gravitate to the exposed surfaces as well.
At best you might be able to shift the bugs out to the edge out of sight.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
laurent será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 7
Ao todo: 83
