Ir para o conteúdo principal
Informações de reparo e desmontagem para os fones circum-auriculares sem fio com cancelamento de ruído Sony WH-1000XM3.
Can I add multipoint Connection?
I recently bought Bose QC headphones and I realize that I like my old Sony’s better but I want multi point connection as well as a new battery. There is barely anything I want in the new one aside from that.
Is it possible to swap out the headphones Bluetooth part for something newer? Is there a way for it to think it’s a WH 1000 XM4?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
It might be but it would surprise me manufactures usually make it impossible to swap parts between different generations to make repairs harder but you might be lucky, even if it is possible it's not likely to be a simple procedure and I'd be amazed if the software still worked. Hope that helps.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Darth Darth será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 22
Ao todo: 318
