Ir para o conteúdo principal
Connecting charge port and speaker antennae
When replacing the charge port, the speaker and charge port antenna are disconnected from the logic board and then, obviously, need to be reconnected.
  1. Can each antenna be connected to either port on the logic board or do they need to be to their original location. On the iPhone 7 Plus they snap in side by side. Easy to get them confused.
  2. Any tricks on getting them to snap into place? They either go right on, or it’s a battle.
  3. What is the function of antenna that comes off the charge port?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
1: I don't know what you mean.
2: Try aligning the connector pin and have them connected first, then clip then to the side of the speaker.
3: A combination of primary cellular and diversity wifi. Modern phones are too complex to use one antenna just for one feature.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Chrissy95 será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 2
Últimos 30 dias: 3
Duração total: 19
