Ir para o conteúdo principal
Nintendo's first 3DS handheld device released February 2011, identified by model number CTR-001.
20 Perguntas Visualizar todos
Charging light comes on when plugged in but no battery installed.
As title says. 3DS charge light will come on even if no battery is installed. If I then install a battery the charging light stays on. Here is the weirdest part. If I then unplug the charger the charging light stays on if the battery is plugged in...
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi!
Okay, but does the 3DS turns on (when the battery is installed)?
If not, I would try a new battery first and see how that goes. If the same thing happens, then you might want to check the charger. Is it the original charger you are using?
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Tristan Williams será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 11
