Ir para o conteúdo principal
Bluetooth Accessory that is a combination Catch Tool for the app "Pokemon Go" and Sleep Tracker for the App "Pokemon Sleep"
My pokemon go plus+ got submerged in water
Hello. my go plus+ got submerged in water and after drying all the components. it wont turned on and i notice some of the SMD on white board are broken. so is it possible to get the type of the SMD? i thought replacing it should do the work
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi! Do you mean a SMD LED? Can you share some pictures with us?
Anyway, when it does have water damage, the best thing to do is to check for corrosion and clean it roughly with isopropyl alcohol! Make sure that all the corrosion is gone and everything looks clean again!
Hopefully after this it works fine. If a component need to be replaced, then it's for the best to replace it before you are going to try it again.
Not sure if there are any parts available for the Pokemon Go Plus.. When it's a LED you can probably find a replacement part as those are universal (you do need the right LED off course).
Esta resposta foi útil?
Pontuação 4
Adicionar a sua resposta
DADANG será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 19
Últimos 30 dias: 73
Ao todo: 982
