SE 2022 Charging Port Available?
Is a replacement charging port available for the Iphone SE 2022?
Esta é uma boa pergunta?
I'm not clear as to whether you were set on getting a genuine Apple replacement part or not, but if not the ports seem to be readily available on several sites such as Amazon, eBay and AliExpress.
iPhone SE 2022 Charging Port Flex Red - eBay
Note that last one is in red; it's strictly cosmetic though so it would work fine; of course if you look a bit harder than I did you'll undoubtedly find the right color for your phone.
Finally if for some reason you are dead set on a genuine Apple part, I did run across a used one on eBay.
Charging Port For iPhone SE 3 2022 - 3rd Gen Dock Connector Flex Cable in Black - eBay
All in all, the charging port for your phone doesn't appear to be any harder to get than that of any other given phone.
I realize you're probably aware of this already, but here's the guide for that specific repair on your phone.
iPhone SE 2022 Lightning Connector Assembly Replacement - iFixit Repair Guide
Esta resposta foi útil?
I kept finding the older part, thanks Jerry!
Here’s a link to the Apple repair guide Apple's iPhone SE 2022 Repair Guide
I’m surprised Apple doesn’t offer the part as it’s one that often wears out or gets damaged by sand. A quick search I’m unable to find the part.
Últimas 24 horas: 1
Últimos 7 dias: 5
Últimos 30 dias: 32
Ao todo: 304
