Ir para o conteúdo principal
A1706 / EMC 3071—Released in November 2016, this 13" Macbook Pro introduces the OLED Touch Bar. Features a dual-core "Skylake" Intel Core i5 CPU and four Thunderbolt 3 ports.
20 Perguntas Visualizar todos
1x Antenna cable would not reattach
I recently replaced the screen on my MacBook Pro (for the 2nd time).
During reassembly, I could only get 2 out of the 3 tiny antenna connectors to seat correctly.
I decided to chance it and booted it up as is. Both Wifi and Bluetooth worked fine; so my question is;
  • What will be broken because one antenna connector is not plugged in?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Missing an antenna means missing a MIMO path, both range and throughput will be impacted.
Esta resposta foi útil?
Pontuação 3
2 comentários:
Thanks... that makes sense. Will this impact affect both Wifi and Bluetooth? I assume yes, but thought I'd check.
por
@mrtimshel - MIMO is a WiFi standard as such only effects your WiFi if it was the second WiFi antenna that you left off. If you damaged the Bluetooth then the lack of a proper antenna reduces its range as only the antenna connection stub is acting as your antenna limiting its range.
por
Adicionar a sua resposta
Tim Pring será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 1
Duração total: 12
