Ir para o conteúdo principal
Guias de reparo, informações sobre desmontagem e resolução de problemas para o terceiro grande redesenho do popular computador de mesa compacto Mac mini da Apple, lançado em outubro de 2024. Equipado com SoCs M4 e M4 Pro e um mínimo de 16 GB de memória unificada.
How is the SSD installed
Is the SSD soldered?
Esta é uma boa pergunta?
Pontuação 17
2 comentários
it is not soldered in but like the Mac studio you still can not replace with larger according to people who have been trying today
por Compartilhar
Apparently Mac Mini with M4 Pro has different main board layout and its SSD module has non-standard shape.
https://support.apple.com/en-us/121003
por Compartilhar
Adicionar um comentário
4 respostas
Solução escolhida
Imagem
It's not soldered
Esta resposta foi útil?
Pontuação 32
10 comentários:
How did you open it up? I also see that only shorter SSDs fit into that place.
por Compartilhar
Thank you very much. So I could exchange the SSD myself? How difficult would you rate this process?
por Compartilhar
wooooo what is this? 2230?
por Compartilhar
@nitro912gr If it is the same style as in the Mac Studio (which knowing Apple is a big IF) it is a proprietary NAND and that’s all. Luckily there has been work for upgrading the Mac Studio so if Apple keeps it all the same it should probably be a drop in replacement. If it is different then in time I imagine it will get reverse engineered just like the Studio in the coming months.
por Compartilhar
One slot? Only, in Studio has two ;)
por Compartilhar
Exibir mais 5 comentários
It's removable, but is it drop-in replaceable? We see that they are already using proprietary connections for it which is to be expected of 2013-2017 Apple, but keep in mind that the more recent Mac Studios had firmware locks to prevent people from simply swapping out their SSDs as they would on any other machine.
I would love to get one of these Minis, but it would suck if Apple threw a fake bone to the right to repair community.
Pontuação 1
2 comentários:
No, it’s not a simple drop in! Even when the 3rd party modules become available, without a second system to run Configurator2 (DFU Mode) to process the Flash module (aka NAND) so it’s married to the system. Then prep the drive and install the OS with the last step restoring your stuff from a good backup.
por Compartilhar
@danj 👍 thanks, you clear explained the process to mod original ssd ;-)
por Compartilhar
The SSD is removable and upgradeable, there are 3rd-parties managed to produce a compatible SSD card that fits into the proprietary slot. With the same or compatible NAND chips on the replacement SSD card, upgrading the SSD on the Mac mini M4 turns out to be quite feasible.
Pontuação 0
1 comentário:
Not that easy if you need to build it first!
por Compartilhar
Just like the previous model and how all of the M Series MacBook systems the RAM and storage (Flash) is soldered to the logic board. Only the Studio and Mac Pro systems have custom Flash storage modules, not a true SSD.
Pontuação -2
8 comentários:
It's not soldered down. Get your facts right and stop assuming it's like earlier version.
por Compartilhar
Yeah get your facts right mate!
por Compartilhar
Hey @joehill58422, Chill out a bit. this was before the new post.
por Compartilhar
Bro I’m only playing with ya lol
por Compartilhar
I’m happy what I was told was wrong!
por Compartilhar
Exibir mais 3 comentários
Adicionar a sua resposta
Douglas Smith será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 28
Últimos 30 dias: 129
Ao todo: 39,707
