Ir para o conteúdo principal
Released September 16th, Apple's "smaller" flagship smartphone features a 6.1" ProMotion OLED, a triple-lens rear camera system, 5G, and a newly designed "Dynamic Island" around the front-facing camera and top sensors. Successor to the iPhone 13 Pro.
20 Perguntas Visualizar todos
Panic logs- is it the charge port?
Just wondering could someone interprit my panic log.. thanks!
I figure its the Charge Port Flex?
"kernel" : "Darwin Kernel Version 23.6.0: Fri Jul 5 18:05:47 PDT 2024; root:xnu-10063.142.1~1\/RELEASE_ARM64_T8120",
"date" : "2024-10-26 17:56:39.25 +0100",
"panicString" : "panic(cpu 2 caller 0xfffffff030fdb648): SMC PANIC - ASSERTION FAILED: target\/d74\/target.cpp:266: 0,
SMC BSC failure, spreadsheet ver(*10) 150\nS.sensor array 0 - 4 is 0x0, 0x100000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n - Misc(2) OUTBOX1 not ready\nASSERTION FAILED: target\/d74\/target.cpp:266: 0, SMC BSC failure, spreadsheet ver(*10) 150\nS.sensor array 0 - 4 is 0x0, 0x100000, 0x0, 0x0, 0x0 \nF.sensor array 0 is 0x0\n\n\nRTKit: RTKit-2419.140.12.release - Client: AppleSMCFirmware-4283.140.4.d74.REL\n!UUID: 5cf13dfa-9869-3b7b-a00c-edbeb929a232\nTime: 0x00000001eec26d06\n\nFaulting task 2 Call Stack: 0x000000000004eae4 0x000000000004e488 0x000000000004e2a0 0x00000000000512c4 0x00000000000047e4 0x0000000000020e74 0x0000000000024068 0x000000000003cbf4 000000000000000000\n\nChinook ASC Async error info: \nl2c_err_sts 0x5000fbfc00000000, l2c_err_adr 000000000000000000, l2c_err_inf 000000000000000000\nlsu_err_sts 000000000000000000, fed_err_sts 000000000000000000, mmu_err_sts 000000000000000000\ndpc_err_sts 000000000000000000\n\nMailbox (0): (0)\n Inbox AKF_KIC_INBOX_CTRL = 0x00020001, AKF_KIC_MAILBOX_SET = 0x11111101\n Outbox AKF_AP_OUTBOX_CTRL = 0x00020001, AKF_AP_MAILBOX_SET = 0x00000000\n\n dir endpoint timestamp msg\n ==== ============ ==================
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Nope, according to the best information we have, it's most likely your Power Button Flex Cable. Apple is making it harder and harder for repair shops and customers to interpret their error codes by changing the codes with every new model. We've got a wiki page that lists all the codes we know and their meanings.
iPhone SMC Panic Assertion Failed - iFixit
Here's what it has to say about your phone and the code it's showing.
iPhone Model iPhone 14 Pro and Pro Max
Sensor Array 0x100000
Likely Issue Power Button Flex Cable
I wasn't able to locate any guides or videos specific to that part on your phone, but fortunately Apple has started releasing their repair guides, and iFixit has a copy of the one for your phone right here.
Apple's iPhone 14 Pro Repair Manual - iFixit
Imagem de Fix an unresponsive power or volume button with this replacement flex cable assembly.
Produto
iPhone 14 Pro Power and Volume Button Cable
$29.99
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Barnes será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 5
Últimos 30 dias: 11
Duração total: 66
