So the headset doesn't turn on after battery replacement error.
Meme Story to ignore:
So.... quick question if I were... to accidentally connect the new battery with the wrong polarity and then leave it charging for 30min... watch the tutorial again realize that the polarity is wrong open it up again and then correct the polarity and the thing doesn't power up... would it break the headset... just asking for a friend :'L
Actual story:
I saw the tutorials, I bought the battery, I didn't have the "tools" the pointy thing for the polarity and I kinda had a little bit of fear of removing the battery and exploding in my face, so I decided to go the a local cellphone repair shop and told them about it... they didn't check the polarity, when I went to pick it up they told me that the thing was charging and working. In my home I connect it but the LEDs didn't turn on. I opened it up and yep they didn't even verify the polarity.
With an old multimeter I tested that the battery had 3.~v DC charge... but the headset doesn't power up. And I heavily suspect that it's gone.
When I connect it for a split second the led powers up before turning off.
Edit:
I bought the same battery of this answer.(the one from the chosen solution)
Esta é uma boa pergunta?
