Ir para o conteúdo principal
Repair guides, disassembly, and troubleshooting information for the iPhone 16 Pro Max, released September 20th, 2024. The flagship smartphone features a 6.9" ProMotion OLED display, Apple's A18 Pro SoC, a triple-lens rear camera system, and the new Camera Control button. Successor to the iPhone 15 Pro Max.
4 Perguntas Visualizar todos
Panic full error, restarted unexpectedly
I've had my iPhone 16 Pro Max for three days, and while it was sitting idle, the phone restarted on its own. It only happened once, but when I checked the analytics reports, I found a full panic log. Should I be worried?
"panicString": "panic(cpu 0 caller Oxfffffff04987ab70):
"AppleOLYHAL: PCle device findPCICapability failed'''@AppleOLYHALPlatformFunction.cpp:381\nDebug
ger message: panic/nMemory ID: Oxff|nOS release type:
User\nOS version: 22A3370\nKernel
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Update: I contacted apple support, they found after diagnosis a system defect, I did a full reset to my iPhone, and the diagnosis shows everything is working properly.
I did a diagnostic myself too, and everything is working great. But I don’t know what to do since I’ve never encountered such issue with my previous iPhones.
iPhone working normally, no weird behaviours
por
Adicionar um comentário
2 respostas
Pergunta mais útil
Generally we have the best luck figuring out panic logs given a bit more context; would it be possible for you to copy'n'paste or screenshot the whole first page of the panic log? The information you've posted doesn't look familiar to me so perhaps a little more data could help us get an idea of what's going on.
It is entirely possible for a software error to cause a kernel panic, so if that's what happened then the restore you did could well have fixed it permanently, although it's a bit unsettling not knowing what caused it in the first place. We do have a whole wiki page courtesy of the amazing @flannelist devoted to kernel panics, plus one on some specific kinds of errors on newer iPhones like yours. Here's a link to both of them for you to take a look at.
iPhone Kernel Panics - iFixit
iPhone SMC Panic Assertion Failed - iFixit
Alisha, have you seen anything like that AppleOLYHAL name?
Esta resposta foi útil?
Pontuação 3
2 comentários:
Not specifically. I would have to dig through some schematics, but some of that stuff is getting sparse because we haven't gotten any leaked schematics since iPhone 12.
por
@flannelist I'm at a loss on the nomenclature here; I might suggest that the HAL part could stand for Hardware Abstraction Layer, but that still leaves the OLY part that I haven't even got a guess for.
por
Experiencing a sudden restart on your iPhone 16 Pro Max along with a panic log in the analytics is not necessarily a cause for immediate concern, but it could indicate an underlying issue. Panic logs typically occur when the system encounters a serious problem, such as a software crash or hardware issue, that forces the device to restart to protect itself. A single instance of this may be a temporary glitch or a one-off event.
However, if it happens frequently, it might point to a deeper issue—such as a problem with iOS, a specific app, or even hardware like the battery or internal components.
Pontuação 0
Adicionar a sua resposta
alaa elarchi será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 77
Duração total: 976
