Ir para o conteúdo principal
The Aspire 3 A315 is a repairable laptop by Acer.
20 Perguntas Visualizar todos
Why my laptop is not turning on and not charging?
My laptop was on and charging then suddenly it stops charging and after a minute it switches off and smoke comes out of the USB ports, then it never switches on again. I unplugged the charger immediately and it was too late as I also came to realize that my charger is bend. I tried to open it so that I can inspect it myself, but it does not show any signs of burns from the inside and I tried smelling it so that I'd find out where the smoke was coming from then I found out that it is from the line of the charging port and the USB ports only. I am looking for a fast response with help. THANK YOU
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Double check the condition of the mainboard and every internal component.
Also, unplug the battery and try the charging cord again. There may be something wrong with the battery module, and not the actual mainboard.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Raymond Maleka será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 23
