Ir para o conteúdo principal
Informações de reparo e desmontagem do smartphone Pixel 8a da Google, lançado em 14 de maio de 2024. Identificável pelos números de modelo GKV4X (5G Sub 6GHz) e G8HHN (5G ondas milimétricas + Sub 6GHz).
FingerPrint doesn't work after screen replacement
Hi, I recently made a screen replacement over my Pixel 8a (EU-630084) with no problems.
After replacement, I did the fingerprint calibrate process with my laptop. Any error received, but after reboot my phone, the diagnostic process says the fingerprint FAILS. What can i do
Esta é uma boa pergunta?
Pontuação 7
1 comentário
You need to ask for a new replacement. The new one works fine.
por
Adicionar um comentário
3 respostas
Solução escolhida
I completed replacement yesterday, same issue.
Is there a missing instruction ?
Esta resposta foi útil?
Pontuação 0
1 comentário:
Yes ensure that while you are changing the display kindly see the connector of fingerprint scanner is properly connected to displays connector or glass was clean and neet
por
It happend to me as well.
Something must not be right
Pontuação 0
I'm not sure how this is answered? I'm facing the same issue
Pontuação 0
2 comentários:
You need to ask for a new replacement. The new one maybe works fine
por
Only removing the fingerprint scanner from the new screen and replacing it with the one from the old screen worked.
por
Adicionar a sua resposta
Carles Gomez será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 55
Ao todo: 963
