Ir para o conteúdo principal
O novo modelo da Apple para a linha 14 apresenta uma OLED de 6,7 polegadas, como aquela do Pro Max, mas vem com as mesmas funções que o iPhone 14, com uma configuração de câmera dupla e chip Bionic A15 com GPU de 5 núcleos.
iPhone 14 plus reboot randomly
Hello everyone, I'm posting a message here because my phone (iphone 14 plus) crashes and restarts by itself, I have the crash report, I need you to try to solve the problem, it's been like this for a month now, it's driving me crazy, I've switched back to the iphone 8 plus just long enough to understand, so if anyone has a solution I'll take it! https://pastecode.io/s/qoixm17c
Esta é uma boa pergunta?
Pontuação 0
1 comentário:
Your iPhone may have a damaged battery, or it has a damaged. internal part. Maybe iOS itself is corrupted and needs to be restored, if that's the case then you will need to restore the phone using iTunes.
por
Adicionar um comentário
1 resposta
I had similar issue, was under Apple Care, they rebuilt the entire phone. At a service center, it was great till Apple care ended, a few months.
Back to the same issue, random reboots and now randomly heats up.
Tried:
Removed protective case.
Turned off all background apps
Turned off app updates/refresh.
Deleted apps.
Do not carry in my pocket.
Bought a new Apple Charger/cord.
Do not use the induction charger any longer.
All this helped but still have the issue it is all random.
Do not expect a lot of help from Apple.
Irony, I traded up from I phone 11 with no issues, to the 14 plus, that was great for a few months.
Good luck!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Matheo Maufroy será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 39
Ao todo: 305
