Ir para o conteúdo principal
Repair and disassembly information for Logitech's G Pro X Superlight wireless gaming mouse. Identifiable by model number MR0106. Released in December 2020.
Scroll wheel not working after installing a replacement.
The middle click was not working on the mouse so I got a replacement. After the replacement, the wheel stopped working and the middle click didn't improve also. This was also the same with the old button board.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
You say you got 'a replacement' but do not specify for what: a replacement for the 'middle click' sounds strange.
Two things can go wrong here.
  1. The middle click not working: If you open the mouse you'll find the wheel shaft rests on a small micro switch. Determine if it seats properly and if you can hear a 'click' sound when pressed.
  2. If the wheel doesn't scroll, here's what I found on mine: A plastic wheel with a soft plastic/rubber 'tyre' (or tire in American spelling) covering it. My tire was slipping on its wheel - both very smooth - and the tire wasn't a tight fit any longer. I roughened up the wheel a bit and dabbed a drop of super glue on the wheel bead then re-fit the tire - problem solved.
Esta resposta foi útil?
Pontuação 0
4 comentários:
I replaced the hole button assembly the above is a link to what I bought
por
I also, feel the click
por
I can also feel the notches when I spin the wheel
por
Adicionar a sua resposta
james1998hodges será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 28
Ao todo: 296
