Ir para o conteúdo principal
iPod Classic 6th Generation. Model A1238 / 80, 120, or 160 GB hard drive / black or silver metal front
I have no sound
when i plug my ear buds in/or speakers i have no sound
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
I assume you've checked different headphones/speakers that you know work with other audio sources, correct?
if so, one other thing to try would connecting to some audio output device via the dock connector (speaker dock, car adapter etc) -- if you have such thing available. if sound comes out via dock connected speakers then at least you know it's not likely a logic board problem.
otherwise it's probably your headphone jack. you can find the repair guide here
before purchasing a replacement headphone jack, you might first want to confirm that the ribbon cable securely connected to the logic board.
Esta resposta foi útil?
Pontuação 1
You can also use the end of a small tube of hand lotion etc. Works great!!!
Pontuação 0
Adicionar a sua resposta
steven sharp será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 11,048
