Ir para o conteúdo principal
A1708 / EMC 2978 — Released October 2016, this entry-level MacBook Pro retains its traditional function keys (as opposed to the OLED Touch Bar). The function key version packs an Intel Core i5 and two Thunderbolt 3 ports.
Part number for Fan Connector ZIF Connector
Hi,
I am looking for the part number for this ZIF connector pictured, which connects the fan to the case. I'm sorry I don't have a picture of it with the tape removed, I forgot to take this picture.
I removed this part to clean the fan and the little plastic "clip" that holds down the ZIF connector broke off. I'd like to try and find a new one to see if I could re-attach the "clip" (or worst-case scenario the whole connector with some micro-soldering) but I cannot figure out this part.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Don't know the part number, but I think this has what you're looking for—the "No 2" option is the 5pin fan ZIF connector for the A1708. You could also look for a damaged or used top case online and get one of those to pull the connector clip from. Good luck!
Esta resposta foi útil?
Pontuação 2
4 comentários:
Thank you @zpl ! I ordered that, will respond here and accept as the answer if it works. Appreciate you finding that link!
por
No problem! Glad to help!
por
This part arrived and it was exactly what I needed, great find! I was able to replace the "clip" and the connector worked as expected. Thanks again!
por
Awesome! Glad to hear it was a success!
por
Adicionar a sua resposta
mark será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 14
Ao todo: 106
