Ir para o conteúdo principal
The Dell Latitude 3510 is a laptop for business released in 2021. This guide assists with repair of the laptop.
Touchpad and Audio port not wroking
I have issues with Dell Latitude 3510's touchpad and audio port, sometimes touchpad works fine but sometimes it wont work and also the cursor shakes without even touching the touchpad , sometimes mouse opens and closes task on its own without even touching the touchpad and also i have issues with audio port , it doesn't connect with any music system , if i want to connect it i have to restart the whole system and if bymistakely the audio jack gets out the system again needs a restart to reconnect the audio jack with audio port
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi,
Not sure if you have tried the Dell troubleshooting reset:
Dell states that the reset can resolve residual power issues that can create several issues with the laptop.
Hope this helps
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Beatz Rope será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 5
Ao todo: 27
