Ir para o conteúdo principal
This car is Identified as the model G11. The Nissan Almera is a line of automobiles that has been manufactured by the Japanese car manufacturer Nissan from 1995 to the present year. It was essentially the European export-market version of the contemporary Nissan Pulsar, the first generation, and of the Nissan Bluebird Sylphy, the second generation.
1 Perguntas Visualizar todos
Why is my ac fan not working
ac fan not running
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
There are several reasons this could occur
  1. The fan motor may be defective and needs to be replaced.
  2. The control or switch that operates the fan may be defective and needs to be replaced.
  3. There is no power connected.
  4. A switch is turned off or fuse has blown or a circuit breaker is tripped.
  5. The fan blade may be stuck
These are general reasons, depending on the air conditioner. There may be other reasons. In order to help I would like to know if it is a window, air conditioner, a central air conditioner, or some other type of air conditioner.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Rohan será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 2
Últimos 7 dias: 14
Últimos 30 dias: 16
Duração total: 42
