Ir para o conteúdo principal
Can't insert underdash fuses
I am trying to replace 3 fuses for 3 windows. I got the old ones out with the help of the fuse puller, but I can't get the new ones in. Large hands, really hard angle. I can see where they should go in, but they won't, and I'm afraid to push too hard for fear of damaging something. Does anyone have any advice? Thanks in advance.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
@johnb12099 if you have the proper fuses that are compatible with the ones you removed, the only way is to line the fuses up with the contacts and push hard. Now, the other possibility is to find somebody with smaller hands in your social circle and see if they can help you with that. Otherwise, I would try a "shade tree mechanic" and see if they would do it for you. Might cost you a few $$ but may work in your favor.
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
John B será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 9
Últimos 30 dias: 28
Ao todo: 140
