Ir para o conteúdo principal
Repair and disassembly information for the second-generation iPhone SE that was announced and released in April of 2020.
iPhone Se 2020 Panic Full
Hello,
Recently i dropped my phone and the microphone died, a week later the phone started shutting down every 3 min, the phone did it 3 time in a row and stopped doing it. A day later it started shutting down every 2 minutes withou stopping.
I replaced the charging port and didnt help (ps: the microphone is working now), bellow this is the new panic full after the replacement.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi,
Did you install a genuine/original charging port flex? A non-genuine part will not work, and you will continue to have this problem until you install a genuine part.
Tip: The original charging port flex will have an Apple logo.
BR
Francis
CelMetro
Esta resposta foi útil?
Pontuação 1
Hi Leonardo,
Your instincts were right on with replacing the charging port assembly, as that's exactly what your panic log indicates is at fault. Here's the smoking gun:
According to the iPhone Kernel Panics wiki page, that sensor is indeed located on the charging port assembly.
I have to disagree with Francis regarding the necessity of buying genuine Apple replacement parts; I've replaced dozens of iPhone parts with aftermarket parts and rarely had an issue with them.
Given that you're still having problems after replacing the port, that leaves only a couple of possibilities. First you could have gotten a bad part; it happens occasionally. It should be relatively straightforward to order one from a different supplier and see if replacing it yet again fixes the issue.
On the other hand, if you check the Likely Issue section, it also states that it could be a problem with the FPC connector on the motherboard where the charging port flex cable plugs in. So you will definitely want to unplug it again and check it carefully with a magnifying glass and a bright light. If there are any bent pins they can sometimes be straightened with some fine tip tweezers, but of course broken or missing pins are much more problematic.
If everything looks good, clean both sides of the connector with 90% or higher concentration isopropyl (rubbing) alcohol, give it a moment or two to dry, then carefully plug it back in and see if it makes any difference. If not, I'd suggest biting the bullet and replacing it once again.
Let us know how it all turns out for you.
Pontuação 1
Adicionar a sua resposta
Leonardo será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 3
Últimos 30 dias: 18
Ao todo: 173
