Ir para o conteúdo principal
The Karcher K4400G is an electric pressure washer designed for home and light commercial use. With a 1800 watt motor, it can produce up to 2200 PSI of water pressure and 1.3 gallons per minute flow rate, and comes equipped with a 35-foot hose, 20-foot power cord, and a detergent tank. Explore this page for more information and repair guides for the K4400G model.
1 Perguntas Visualizar todos
Karcher K4 Full Control Pressure Washer Lost Power
Hi my Karcher K4 full control pressure washer will not start. its an 1800w. I have removed the hose and let water run through for 5 minutes in case of air lock, and also changed the 13 amp plug but it still wont start. It's 4 years old.
Please can anyone advise next steps?
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
2 respostas
Pergunta mais útil
Hi Chrissy,
Karcher provides a set of manuals for your pressure washer here.
K4 Electric Pressure Washer, 1900 PSI, 1.603-152.0 - Kärcher
Buried in the midst of those pages is one particular page that has a set of troubleshooting instructions.
Step through the Motor will not start section then come on back and let us know what you found and we'll see if we can figure out your next steps.
Esta resposta foi útil?
Pontuação 1
When first switched on (plugged in etc.) turning front dial from 0 to 1 the machine should pulse for about a second (Ie motor starts then stops). If you do not hear this then it is an electrical issue. Checking plug fuse is the correct first step. If that is ok the it is internal which means some skill and knowledge and opening the case (quite easy but about 16 screws). Problems could be 1) broken switch rod, 2) broken on/off switch, 3) damaged cable 4) damaged motor. Other than the switch rod you really need a multimeter or similar to test parts. If you have skills then all parts are available and cheaper than scrapping the unit. If you do not have the skills then Google Repair Cafe. This is an international organisation of volunteers who will help, advise and repair, often for free. (Other than the cost of parts) There may well be one near you (there are thousands around the world and hundreds just in the uk.
Remember, old Karcher never die, they just need repair. Sometimes not economic if you have to pay a shop to do the work but Repair Cafe is the way to go.
Pontuação 1
Adicionar a sua resposta
Chrissy será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 7
Últimos 30 dias: 22
Duração total: 71
