Ir para o conteúdo principal
O novo modelo da Apple para a linha 14 apresenta uma OLED de 6,7 polegadas, como aquela do Pro Max, mas vem com as mesmas funções que o iPhone 14, com uma configuração de câmera dupla e chip Bionic A15 com GPU de 5 núcleos.
Cellular Issue - unable to access cellular data
Water damaged, dried out by opening the back and front keeping in rice for 12 hours. Phone came back on. Old screen no display so put a new screen and the replacement works. Two Problems Cellular Issue (no bars no net) and Phone keeps restarting.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi,
It looks like water has affected the motherboard. iPhone 14 has a dual motherboard; the top board is for UI, and the bottom is for communications (network/cellular). Water ingress can affect the connecting layer and cause corrosion between the pins. This could be the reason why the iPhone is restarting and does not have cellular (baseband)
This is going to be a chip-level repair, and only a trained professional can perform such complex repairs. The boards will have to be separated, serviced, corroded parts replaced, and the boards reballed and refixed.
BR
Francis
CelMetro
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Arbin Shrestha será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 9
Últimos 30 dias: 13
Ao todo: 207
