Ir para o conteúdo principal
The Game Boy released on April 21, 1989 in Japan, followed by North America on July 31, 1989, and lastly in Europe on September 28, 1990. It is characterized by a large grey casing and model number DMG-01.
20 Perguntas Visualizar todos
Super Mario Land 2: 6 Golden Coins question issue
My boyfriend and I got Super Mario Land 2: 6 Golden Coins and found out that there is glue inside the cartridge and can't open to replace the battery for the game. Any suggestions would be greatly appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
I'm not sure, but if the cartridge is glued shut you may be able to dissolve the glue by gently applying isopropyl alcohol, maybe with a Q-tip, and then you could try to cut away at it with something like a guitar pick or plastic card. It's hard to say exactly without a picture of the cartridge. Good luck!
Esta resposta foi útil?
Pontuação 0
2 comentários:
I added the photo. Hopefully that would help
por
Hmm, that seems like it could be tricky to remove or break the glue. There might be some products online to dissolve that kind of glue, but I'm not knowledgable about that. You could also try to cut it with a really small metal object like a razor blade or metal tweezers, but that could be difficult and/or risky, so if you choose to do that be careful!
por
Adicionar a sua resposta
Tonya Ramsey será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 51
