Ir para o conteúdo principal
The PlayStation Vita is the successor to the PSP. It contains a beefed up processor and graphics, and includes the addition of a second analog stick. It was released February 15, 2012.
Problem with power and hone button
So I havnt used my vita and ages so it was having power issues like trying to shut itself off like something pressing the home button even if I tried to clean under it it still does it. The home button doesn't respond either probably cause of the power button thing but all other buttons work. My first try was replacing the battery with a new one but still happens.
I was wondering if someone has had the same issue
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
So you are having issues with the power button? If this is the case, the best thing to do is to replace the left button board and see if that fixed it.
Guide: PlayStation Vita Left Button Board Replacement
If this didn't fixed it, you do need to check the motherboard.
Good luck and please let us know how it goes!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
50MiraGaming será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 4
Últimos 30 dias: 15
Ao todo: 138
