Ir para o conteúdo principal
Help:How to open housing (preferably non-destructively)
The screws inside the housing came off and it was rattling around inside.
I chose these because I heard they were sturdy, but I didn't expect them to break from the inside.
I'm sure I could fix it easily if I could open it, but I don't want to remove the adhesive from the earpads if at all possible(just because it's a pain to reattach them).
If you know, please let me know.
Esta é uma boa pergunta?
Pontuação 1
1 comentário
Use a pry tool to pull one of the lips of the earpads off and carefully pull the rest off using your hands
por
Adicionar um comentário
1 resposta
Solução escolhida
I pulled it with a little force and I was able to remove the ear pads
There was never any glue there in the first place.
Sometimes people make mistakes out of ignorance
Sometimes people create monsters out of ignorance
Sometimes people make knowledge out of ignorance
By the way, how do I put these earpads back on? ......
Esta resposta foi útil?
Pontuação 0
2 comentários:
That doesn't answer anything remotely related to the question how do I take the case off of my headphones without breaking them
por
you can use a flathead screwdriver or a card to push the edges in
por
Adicionar a sua resposta
N.viver. será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 16
Últimos 30 dias: 70
Ao todo: 1,086
