Windows 7 no sound
Hello everyone! I've recently bought a Medion Laptop which had a Windows Vista OS. Because I'm not a big fan of that OS, I've installed Windows 7 Ultimate/32 bit. After installing it, I had no sound or wireless connection. I've fixed the wirelless connection (hardly), but still couldn't fix the sound. And thrust me, I'm no begginer at this. But, since I can't fix this on my own, I'm asking for your help. My laptop model is Medion MD96370 (also says CM2 above that writing), motherboard is WIM2170, Serial Number from bottom of my laptop is SN :30007436. I've tried everything, I've searched and instaled\desinstaled a lot of sound patches and other fixes, but with no results. In the right corner where I should adjust the sound, still shows "x" on audio cone and says "No Audio out put device is instaled". Everest versions show no audio device as well and in device manager shows no audio device either.I've even upgraded it's BIOS, but still no results. If anyone could help me, I would be verry gratefull. Thank you in advance.
Esta é uma boa pergunta?
5 comentários
Have you tried a driver for your sound card?
por oldturkey03
I've tried every driver from medion site...Germany and Uk too, still, no results!
por Xarius
Does your sound card show in your BIOS as enabled?
por oldturkey03
Yesterday, I've installed Windows Vista home premium on a Virtual machine (Virtualbox). After installing it, I've checked device manager and there, by audio devices showd "Intel(r) 82801AA AC'97 Audio controler". But after I restarted the machine, the same problem appeared. My laptop had no sound. :(. I just don't know what to do anymore. :(
por Xarius
So you show your audio device under XP, but not under Win7? Sounds like a definite driver issue
por oldturkey03
