Ir para o conteúdo principal
Repair information and guides for the long-awaited refresh of the popular MacBook Air, featuring Intel's Core i5 processors, an updated Retina Display, and numerous other changes and updates that was released on November 7th, 2018.
Identify capacitor for replacing
Hello
I'm looking for some help identifying a capacitor that's blown so I can order another and replace it. It's on a A1932 MacBook logic board and the capacitor number is C6415, I will attach an image of the schematic where its located.
Thanks in advance
Esta é uma boa pergunta?
Pontuação 0
1 comentário
Do you have the schematics for this system? You should be able to locate it by its number and it will offer the caps info. I’m just stepping out if you don’t have it let us know and I’ll try to find mine.
por
Adicionar um comentário
1 resposta
Solução escolhida
The device you posted the question under is the MacBook Air 15" but you state this is for the A1932 model, which applies to the 13-inch 2018 and 13-inch 2019 model MBAs. If it is indeed the A1932 model, then here is the information regarding that capacitor (see attached image). You may be able to purchase a same-spec capacitor online via aliexpress or mouser or another electronic component retailer. Good luck!
Esta resposta foi útil?
Pontuação 0
2 comentários:
It is indeed the 2018 13" model, I selected the wrong one. Thank you very much for your help
por
No worries! Good luck!
por
Adicionar a sua resposta
YEET_ será eternamente grato(a).
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 6
Últimos 30 dias: 33
Ao todo: 175
