Ir para o conteúdo principal
Mid 2009 Model A1278 / 2.26 or 2.53 GHz Core 2 Duo processor EMC 2326
745 Perguntas Visualizar todos
Pergunta encerrada
Looking for Display Data Cable
Does anybody know where I can buy MacBook Pro 13 Unibody parts?
I had a little accident and poured redbull on my MacBook..after cleaning it the MacBook starts, everything works except the screen, its black. I checked on the Display Data Cable and I can see its broken. Maybe it was a friend when he tried to fix it. The connector of the cable is damaged, the one that is attached to the logic-board.
Where can I buy this product? Im a total Newbie to Mac, please help.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
5 respostas
Solução escolhida
Even if the LVDS cable is damaged you should get a gray screen cause the backlight (screen lightning circuitry) should work. Before buying parts I would connect the MBP to an external monitor then check if the video is normal on the external.
Esta resposta foi útil?
Pontuação 4
2 comentários:
I concur -- in fact suggested it because of the redbull spill. Ralph
por
Apple decided that the internals of the Unibody displays are non-serviceable, so the display cables are a bit hard to come by. Your best best is to check eBay for the part or for a display with shattered glass for cheap from which to scavenge the cable.
Pontuação 3
2 comentários:
Hi
Is it possible to get the cable of any Mac Laptop Screen or do I have to get it of a MacBook Pro 13 Unibody ?? thanks for help.
por
Unfortunately, the cables are pretty exclusive between machines. You would need one specifically from a MBP 13" Unibody. Good luck!
por
If the cable itself was the problem you would be in better shape. If I understand you correctly the connector on the logic board is broken. That being the case you probably need a new logic board. You can try using a external monitor and if that works you could still use the MacBook as a desktop computer.
However if the cable itself is bad that can be replaced for a lot less money. Ralph
Pontuação 1
4 comentários:
I have searched for a source for the cable without luck. Please confirm the cable and not the board is what you need and I'll keep looking. Ralph
por
thanks a lot for this quick answer
thats probably my poor english, only the cable is broken, not the board. however, I couldnt find where I can buy this.
por
The only cable I can find are part of a complete display--if anyone has a source for just the cable please chime in. Ralph
por
Does anyone know the Apple part number for the display cable?
Pontuação 0
1 comentário:
duplicate question
por
http://www.ebay.com.au/itm/Apple-A1278-1...
Pontuação 0
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 1
Duração total: 3,651
