Ir para o conteúdo principal
Is the Wireless Network Adaptor replaceable?
I have an ACER Swift X laptop (N20C12) . The Wireless Network Adapter was working intermittently and now will not see my wireless connections. I have reset the router and all my other devices are working and connecting. Can the Wireless Network Adapter be replaced? Is it on the motherboard? Thanks.
Esta é uma boa pergunta?
Pontuação 0
1 comentário
معمولاً با ریست کردن قطعه مورد نظر در تنظیمات ویندوز این مشکل حل میشود ، در مرحله دوم نصب مجدد درایور قطعه می‌باشد.
در صورت عدم کارکرد صحیح دستگاه ، از یک آدابتور اکسترنال استفاده کنید
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Yes the wireless Network adapter can be replaced.
Click here.
This is for the battery but shows you how to open the case and remove the battery. Never do any interior work without disconnecting the battery.
Go to Step 4 and the Adapter is right in the centre of the photo.
But first of all does it appear in Device Manager ? Is yes then right click delete it and then open "Action" menu selecting "Scan for hardware changes" and Windows will reinstall the driver.
Does it work now. Yes or no? If no replace the adapter.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Ray será eternamente grato(a).
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 4
Últimos 30 dias: 7
Ao todo: 98
