Ir para o conteúdo principal
Released on September 24th 2021, the iPhone 13 mini is a smaller version of Apple's iPhone 13 and is the second mini iPhone. It features a 5.4-inch OLED, an A15 Bionic processor, and dual rear cameras.
35 Perguntas Visualizar todos
Phone keeps restarting randomly and Wifi/BT not working
Hi there,
The device got its screen replaced the preowner said to me.
Its restarting randomly and I cant find Wifi connections (only if i'm very close to the router)
cant find bluetooth connections and also no celluar too (no service).
The Wifi and bluetooth is not greyed out.
I reinstalled the latest iOS multiple times. still no fix.
Crash log: https://pastebin.ai/r5rumylila
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Solução escolhida
Hi Ed,
Thanks for including the panic log; that's exactly what's needed to debug boot loop issues like yours.
In your case your panic log has the smoking gun right here.
"panicString" : "panic(cpu 1 caller 0xfffffff035e546c8): SMC PANIC - ASSERTION FAILED: target/d16/target.cpp:263: 0, SMC BSC failure, spreadsheet ver(*10) 190
S.sensor array 0 - 6 is 0x0, 0x400, 0x0, 0x0, 0x0, 0x0, 0x0
iFixit has a new Wiki page specifically devoted to SMC PANIC - ASSERTION FAILED errors, as that's how most of them are now logged on iPhones starting with the 13.
iPhone SMC Panic Assertion Failed - iFixit
According to the best information we have available, here's the source of your problem.
iPhone Model Sensor Array Likely Issue
iPhone 13 Mini 0x400 Gyroscope (located on the bottom board)
The bad news here is the part that's causing the looping is located on the bottom board of the sandwich board assembly, and as such is going to be extremely difficult to repair. Here's a quote from our resident expert Alisha ( @flannelist ).
That came on a question from another user with the exact same problem.
iPhone 13 mini restarting, SMC PANIC - ASSERTION - iPhone 13 mini - iFixit
Another user stated that they had the same problem and that changing the charging port flex cable assembly fixed the issue for them. Unfortunately they didn't provide any details so it's not clear if by "same problem" they meant they had the 0x400 error code, or just that their phone was rebooting. If the latter, then it's likely not really relevant.
Esta resposta foi útil?
Pontuação 2
Adicionar a sua resposta
Ed Mahoney será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 22
Duração total: 22
