Ir para o conteúdo principal
The Game Boy released on April 21, 1989 in Japan, followed by North America on July 31, 1989, and lastly in Europe on September 28, 1990. It is characterized by a large grey casing and model number DMG-01.
20 Perguntas Visualizar todos
Red light, no picture or sound
Hi,
Iv purchaced a gameboy that has power to the led but no picture or sound.
Iv tested the output from the battery and its outputting 6.4v.
Psu points are
Vcc 6.26v
Gnd 0
Minus -276mv
Plus -151mv
Now i no these outputs are wrong but im getting 6.24v on the board up by the switch when its turned on.
Strangly when i was checking the voltages i shorted the Vcc & ground together and the device started up, screen & volume was working and i was able to use the device, but when i turn it off it wont turn back on, would this suggest a short on the psu or on the board?
Any advice appreciated
Update (07/06/24)
https://ibb.co/4KH2N7k
https://ibb.co/VT6X6dQ
Esta é uma boa pergunta?
Pontuação 1
2 comentários
@leeuk have you checked your on/off switch? What about corrosion on the board?
por
Theirs no corrosion anywhere on the board, the on off switch i cleaned in ipa and i get resistance cutting off / on when i flick the switch so i persume that would be ok?
por
Adicionar um comentário
1 resposta
Pergunta mais útil
Most of the time it's caused by the board with the screen on it. Could also be the cable which is damaged/broken. When you have an healthy gameboy, and you detach the cable, you get the same result.
Must be an component which is broken on the board with the screen (most likely)..
Esta resposta foi útil?
Pontuação 1
14 comentários:
Perfect ill have a look around that screen board later, it was the fact that if i short the VCC and gnd for a second everything comes on an works fine which through me off and made me think it wasnt a cable issue... strange 🤦‍♂️
por
Alright! Yeah, it still could be the cable or the connector :(... Please check them both and run some tests to see what is failing... Good luck with the repair :)!
por
Iv tested the pins on the ribbon cable to the solder on the board, some of the pins on the board are showing continuity to more than 1 of the pads on the ribbom cable would this be a short on the ribbon?
por
Yeah, could be.. Do you have a replacement board? Just to test if it works? Please check the capacitors there too, could be that one of them failed giving weird values.
por
I dont have another board no :( everything looks ok what i can see, iv just inspected the main board not the screen and came across this resistor that has yellow coming out of both sides... i can see it on some others but alot more on this 1, is this common?
por
Exibir mais 9 comentários
Adicionar a sua resposta
LeeUK será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 6
Últimos 30 dias: 11
Ao todo: 165
