Ir para o conteúdo principal
4.3" widescreen LCD display with a 333 MHz Processor. Model Number PSP98510. Repair for this device requires common screwdrivers and prying tools.
Why is my psp loading forever?
I recently opened up my psp 2000 and after replacing the joystick as it was broken it stopped loading UMD Discs. It has the loading icon but after about a minute it just says "disc could not be read" on a game that worked on it previously and my other psp. Did i disconnect something? Do i need to lube the gears as it's making a whirring noise now? Any help is appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi!
Well first thing to do is to open it up again and be sure that all is connected properly!
Also check if something is damaged (cables etc).
If you are uncertain about a component, please share some pictures with us!
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
ballisticzombie7 será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Ao todo: 140
