How to charge the batterie separat? USB port in camera ist defect
USB port in camera defect
Esta é uma boa pergunta?
Hey hi Otward, you might just want to replace the USB port or if just want to charge it separately then you need to tear it down / disassemble the product. Here is the teardown for the battery: GoPro Hero4 Black Battery Housing and Rear Frame Replacement - iFixit Repair Guide
Also, I am not sure if it is the USB port for sure? So if you think that it is not the USB port than you can just buy a new battery and place it in the camera by following the same teardown guide I have given to put the new battery. Beware that even a simple mistake can break your camera and cost you a lot so make sure that you proceed with caution. Thanks for reading and have a Gorgeous day!!!
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 13
Duração total: 13
