Ir para o conteúdo principal
Reparo e suporte para os controles que vêm com o PS3. Lançado em novembro de 2007 (somente no Japão) e 2008 (outros países), este controle de seis eixos alimentado por bateria de lítio (CECHZC2) é fácil de reparar.
Why won’t my ps3 controller turn on?
I recently bought a used ps3 controller unopened but definitely dropped before. It was missing a trigger. I assume some kid pulled it out. Anyways I tried to turn it on and it didn’t turn on. I even swapped the batteries. With a charged battery. Nothing happened. I opened the board and removed everything’s cleaned the board with 99% ipa. Put it back together. Plugged it in and still nothing. I thought maybe it was the charging port. So I removed the port and replaced them. No idea why it still won’t turn on. Any ideas? Is there a dead chip?
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Pergunta mais útil
Hi Amber!
Yeah it's definitely the motherboard which died and need an replacement.
Could be a lot of things from fuses to the Toshiba IC which died...
I recommend to replace the motherboard completely, this will get it back to working.
Esta resposta foi útil?
Pontuação 1
Adicionar a sua resposta
Amber tech será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 11
Ao todo: 137
