Ir para o conteúdo principal
Apple's top-of-the-line flagship for 2022. Released September 16th, the iPhone 14 Pro Max sports a 6.7" ProMotion OLED, the new Bionic A16 chip, a triple rear camera system, and 5G connectivity. Successor to the iPhone 13 Pro Max.
20 Perguntas Visualizar todos
Are copper wires required for button function?
The flex cable (connecting the power button with the volume up and down buttons) that is also connected to the wireless charging coil has been severed. Upon attempted replacement of said flex cable, I discovered that the existing severed flex cable is connected to small copper wires attached to the wireless charging coil. If I sever those wires and just replace the flex cable, will the buttons be operational? Note: I can do without wireless charging as long as I can still charge the phone via the charging port.
Esta é uma boa pergunta?
Pontuação 1
Adicionar um comentário
1 resposta
For the circuit to work the connection is required. If you are asking about the wireless charging coil it won’t work if severed.
Esta resposta foi útil?
Pontuação 0
1 comentário:
I just need to know if the buttons will work again. Not concerned about the wireless charging.
por
Adicionar a sua resposta
Dawn será eternamente grato(a).
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 3
Últimos 30 dias: 5
Duração total: 53
