Ir para o conteúdo principal
Repair guides, disassembly, and troubleshooting information for the first generation Sony PlayStation 5 DualSense controller, successor to the DualShock series. Identified by model number CFI-ZCT1W and motherboard model BDM-010.
Why does L2 only register if I press down hard?
My L2 button wasn't working after I, stupidly, sprayed some silicone lubricant in it to stop it from squeaking. I disassembled the controler and cleaned the entire L2 assembly with alcohol, the button, ribbon and surface underneath. L2 works again but only if I depress it all the way and squeeze hard. I'm fairly sure it's clean now, but not sure what else could cause this? Any help would be appreciated.
Esta é uma boa pergunta?
Pontuação 0
Adicionar um comentário
1 resposta
Hi Zander!
Most of the time caused by the L2/R2 that's not aligned correctly. Or a issue with the spring.
You can check this one out: https://www.youtube.com/watch?v=DvdgAis9...
Please check if everything is seated correctly.
Good luck!
Esta resposta foi útil?
Pontuação 0
Adicionar a sua resposta
Zander será eternamente grato(a).
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 6
Ao todo: 142
