When I turn on my pc it gets turned on at once but...
But after turning on it gets restarts on its own and keeps on restarting when Starting windows logo Appear
Esta é uma boa pergunta?
Accessing Advanced Start‐up when PC isn't loading:
If your device isn't loading or stuck during boot, you can use this method to access the recovery environment:
After the third interruption, Windows 10 will open into the Advanced Start‐up environment
While in the Advanced start‐up environment, use the following steps to use Start‐up Repair:
If the above doesn’t help do the same as above but this time select “System Restore” from the “Advanced Options?”
Or from an installation disk/flash drive
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 2
Últimos 30 dias: 9
Duração total: 9
