My car engine RPM is fluctuating
Esta é uma boa pergunta?
Greetings Dillip,
The first thing I would do is check for vacuum line leaks and do a Throttle Body Adaptation.
Start engine
If it doesn't improve, check again for vacuum leaks. - If no vacuum leaks can be found. Scan the car with an OBD scanner and check the O2 sensor.
Report back with the results and let me know.
Cheers!!
Moe
Esta resposta foi útil?
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 2
Duração total: 13
