Ir para o conteúdo principal
1.5 Core Solo, 1.66 or 1.83 Core Duo, or 1.83 or 2 GHz Core 2 Duo processor. This covers the first Intel-based Mac Mini models from Early 2006 to Mid 2007.
Possible to upgrade Interconnect Board?
Wondering if it is possible to upgrade the interconnect board with one from a newer model? I saw this question asked once before but with an unsatisfactory answer...
And if it IS possible and i could thereby lose the Pata connection from the optical drive and gain a Sata connection would this sata connection still be limited in speed (ATA100 speeds)?
Thanks in advance!!
Esta é uma boa pergunta?
Pontuação -1
1 comentário
What are you trying to accomplish?
por
Adicionar um comentário
1 resposta
Solução escolhida
According to this vendor they all use the same interconnect board.
If this Answer is helpful please remember to return and mark it Accepted.
Esta resposta foi útil?
Pontuação 0
2 comentários:
Thanks!! Apparently I need to work on my googling skills..... I missed that one. And what i'm trying to accomplish is adding more storage but making it easy for myself with regards to connectors and what not. And general interest as well because I like fidgeting with the thing :-)
por
You can go that way or a self-powered USB Hub will connect many devices.
por
Adicionar a sua resposta
Nico será eternamente grato(a).
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 4
Ao todo: 543
